shelf.config events
shelf.config.mixed
Severity
NOTICE
This message occurs at system boot time, when a stand-alone system's storage configuration is a mixture of redundant paths and single paths.
Corrective Action
(None).
Syslog Message
System is using a mixture of single path, multi-path or quad-path storage configurations.
(None).
shelf.config.mixedha
Severity
NOTICE
This message occurs at system boot time, when an HA system's storage configuration is a mixture of redundant paths and single paths.
Corrective Action
(None).
Syslog Message
System is using a mixture of single path, multi-path or quad-path HA storage configurations.
(None).
shelf.config.mpha
Severity
INFORMATIONAL
This event is generated at the Filer boot time, when it is a HA configuration and all the storage shelf enclosures accessible by the Filer have redundant paths. This message is for informational purpose only.
Corrective Action
(None).
Syslog Message
All attached storage on the system is multi-pathed HA.
(None).
shelf.config.multipath
Severity
INFORMATIONAL
This event is generated at the Filer boot time, when it is a stand alone configuration and all the storage shelf enclosures accessible by the Filer have redundant paths. This message is for informational purpose only.
Corrective Action
(None).
Syslog Message
All attached storage on the system is multi-pathed.
(None).
shelf.config.qpha
Severity
NOTICE
This message occurs at system boot time, when an HA system's storage configuration is quad-path.
Corrective Action
(None).
Syslog Message
System storage is in a quad-path HA configuration.
(None).
shelf.config.quadpath
Severity
NOTICE
This message occurs at system boot time, when a stand-alone system's storage configuration is quad-path.
Corrective Action
(None).
Syslog Message
System storage is in a quad-path configuration.
(None).
shelf.config.single
Severity
INFORMATIONAL
This event is generated at the Filer boot time, when it is a stand alone configuration and all the storage shelf enclosures accessible by the Filer have only one active path. This message is for informational purpose only.
Corrective Action
(None).
Syslog Message
System is using single path attached storage only.
(None).
shelf.config.spha
Severity
INFORMATIONAL
This event is generated at the Filer boot time, when it is a HA configuration and all the storage shelf enclosures accessible by the Filer have only one active path. This message is for informational purpose only.
Corrective Action
(None).
Syslog Message
System is using single path HA attached storage only.
(None).
shelf.config.tomixed
Severity
NOTICE
This message occurs in a stand-alone system when the storage configuration changes from a single-path, multi-path, or quad-path configuration, to a mixed path configuration.
Corrective Action
(None).
Syslog Message
System has transitioned to a mixture of single path, multi-path or quad-path storage configurations.
(None).
shelf.config.tomixedha
Severity
NOTICE
This message occurs in an HA system when the storage configuration changes from a single-path HA, multi-path HA, or quad-path HA configuration to a mixed path HA configuration.
Corrective Action
(None).
Syslog Message
System has transitioned to a mixture of single, multi-path or quad-path storage configurations.
(None).
shelf.config.tompha
Severity
INFORMATIONAL
This event is generated by the periodic storage health monitor process in a HA Filer configuration, when the Filer storage configuration changes from the single path HA configuration to the multi-path HA configuration.
Corrective Action
(None).
Syslog Message
System has transitioned to multi-path HA attached storage
(None).
shelf.config.tomultipath
Severity
INFORMATIONAL
This event is generated by the periodic storage health monitor process in a stand alone Filer configuration, when the Filer storage configuration changes from the single-path configuration to the multi path configuration.
Corrective Action
(None).
Syslog Message
System has transitioned to multi-path attached storage
(None).
shelf.config.toqpha
Severity
NOTICE
This message occurs in an HA system when the storage configuration changes to quad-path.
Corrective Action
(None).
Syslog Message
System has transitioned to a quad-path storage configuration.
(None).
shelf.config.toquadpath
Severity
NOTICE
This message occurs in a stand-alone system. System has transitioned to a quad-path storage configuration.
Corrective Action
(None).
Syslog Message
System has transitioned to quad-path attached storage
(None).
shelf.config.tosingle
Severity
INFORMATIONAL
This event is generated by the periodic storage health monitor process in a stand alone Filer configuration, when the Filer storage configuration changes from the multi-path configuration to the single path configuration.
Corrective Action
(None).
Syslog Message
System has transitioned to single path attached storage
(None).
shelf.config.tospha
Severity
INFORMATIONAL
This event is generated by the periodic storage health monitor process in a HA Filer configuration, when the Filer storage configuration changes from the multi-path HA configuration to the single path HA configuration.
Corrective Action
(None).
Syslog Message
System has transitioned to single path HA attached storage
(None).
shelf.config.toTripath
Severity
NOTICE
This message occurs when a stand-alone system changes to a tri-path storage configuration.
Corrective Action
(None).
Syslog Message
System transitions to a tri-path storage configuration.
(None).
shelf.config.toTripathHA
Severity
NOTICE
This message occurs in a high-availability (HA) system when the storage configuration changes to tri-path.
Corrective Action
(None).
Syslog Message
System transitions to a tri-path HA storage configuration.
(None).
shelf.config.tripath
Severity
NOTICE
This message occurs at system boot time, when a stand-alone system's storage configuration is tri-path.
Corrective Action
(None).
Syslog Message
System storage is in a tri-path configuration.
(None).
shelf.config.tripathHA
Severity
NOTICE
This message occurs at system boot time, when a high-availability (HA) system's storage configuration is tri-path.
Corrective Action
(None).
Syslog Message
System storage is in a tri-path HA storage configuration.
(None).
