repl.physdiff events
Creating your file...
Your file is ready
repl.physdiff.invalid.hole
- Severity
EMERGENCY
- Description
This message occurs when a block to replicate was found to be inconsistent in the source volume. Replication has been aborted to avoid propagating the inconsistency to the destination node.
- Corrective Action
Run wafliron on the aggregate containing the source volume of the replication.
- Syslog Message
Replication of volume '%s%s%s' (DSID %llu) encountered an inconsistent block (VVBN %llu).
- Parameters
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume.
volDsid (LONGINT): Data set identifier (DSID) of the source volume.
vvbn (LONGINT): Virtual Volume Block Number of the affected block.
