ONTAP EMS reference
repl.physdiff events
repl.physdiff EMS events occur when a block to replicate was found to be inconsistent in the source volume.
repl.physdiff.invalid.hole
Severity
EMERGENCY
This message occurs when a block to replicate was found to be inconsistent in the source volume. Replication has been aborted to avoid propagating the inconsistency to the destination node.
Corrective Action
Run wafliron on the aggregate containing the source volume of the replication.
Syslog Message
Replication of volume '%s%s%s' (DSID %llu) encountered an inconsistent block (VVBN %llu).
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier for the volume.
volDsid (LONGINT): Data set identifier (DSID) of the source volume.
vvbn (LONGINT): Virtual Volume Block Number of the affected block.
