The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
haosc.fru events
Creating your file...
Your file is ready
haosc.fru.op.failed
- Severity
ALERT
- Description
This message occurs when the chassis or controller field-replaceable unit programmable read-only memory (FRU PROM) read/write fails.
- Corrective Action
Replace the system chassis or controller, and contact NetApp technical support for assistance.
- Syslog Message
%s FRU PROM %s operation failed.
- Parameters
fru (STRING): Chassis/controller string.
op (STRING): Read/write operation string.
