The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sp.autoconfig events
Creating your file...
Your file is ready
sp.autoconfig.out.of.address
- Severity
ERROR
- Description
This message occurs when the system cannot automatically obtain IP configuration because the subnet associated with the Service Processor does not have any available IP addresses.
- Corrective Action
Expand the subnet range to include more IP addresses with command "network subnet add-ranges". If failures persist, contact NetApp technical support.
- Syslog Message
(None).
- Parameters
subnet (STRING): Name of the subnet associated with the Service Processor.
