cr.redir events
cr.redir EMS events occur when the data scanner skips an inode for which it cannot access the redirector file.
CR.Redir.File.Inaccessible
- Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
- Severity
NOTICE
- Description
This message occurs when the data scanner skips an inode for which it cannot access the redirector file. This might be due to the namespace volume being offline.
- Corrective Action
Bring the namespace volume back online using the "volume online" command. If the problem persists, retry the scan operation.
- Syslog Message
The data file [%s] on data volume [%s] will be skipped by "Volume Check" because the corresponding redirector file on namespace volume [%s] on Vserver [%s] is not accessible.
- Parameters
dataFilePath (STRING): Path of the data file that will get skipped.
dataVol (STRING): Name of the constituent data volume that hosts the data file.
nsVol (STRING): Name of the constituent namespace volume that hosts the redirector file.
vserver (STRING): Vserver hosting the constituent volumes.
