ONTAP EMS reference
dm.cluster events
dm.cluster EMS events occur when resynchronization of the cluster configuration failed in a MetroCluster(tm) configuration.
dm.cluster.rebaselinefailed
Severity
ERROR
This message occurs when resynchronization of the cluster configuration failed in a MetroCluster(tm) configuration.
Corrective Action
Use the "metrocluster check config-cluster resync" command to resynchronize the cluster configuration.
Syslog Message
Cluster configuration resynchronization failed for cluster %s.
cluster (STRING): Name of the cluster whose configuration is being replicated.
