dm.cluster events
dm.cluster.rebaselinefailed
- Severity
ERROR
- Description
This message occurs when resynchronization of the cluster configuration failed in a MetroCluster(tm) configuration.
- Corrective Action
Use the "metrocluster check config-cluster resync" command to resynchronize the cluster configuration.
- Syslog Message
Cluster configuration resynchronization failed for cluster %s.
- Parameters
cluster (STRING): Name of the cluster whose configuration is being replicated.
