hypervisor.version events
hypervisor.version EMS events occur when the hypervisor version is not supported by ONTAP Select.
hypervisor.version
- Severity
ALERT
- Description
This message occurs when the version of the hypervisor is not supported by ONTAP® Select.
- Corrective Action
Move ONTAP® Select to a supported hypervisor version.
- Syslog Message
Unsupported hypervisor version: %s. Supported versions: %s
- Parameters
version (STRING): Current version of the hypervisor.
supported_versions (STRING): Supported versions of the hypervisor.
