wafl.sis events
Creating your file...
wafl.sis.clone.autodelete.file
- Severity
NOTICE
- Description
This message occurs when a file clone is autodeleted
- Corrective Action
(None).
- Syslog Message
'%s' is sent for auto deletion.
- Parameters
path (STRING): File path.
wafl.sis.clone.autodelete.threshold
- Severity
NOTICE
- Description
This message occurs when file clone create operation fails because volume crossed autodelete threshold.
- Corrective Action
Increase the space available to the volume by either adding disks or by freeing space in the volume to allow the cloning operation to continue.
- Syslog Message
File clone creation cannot be completed because volume crossed autodelete threshold.
- Parameters
name (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
wafl.sis.clone.create.failed
- Severity
INFORMATIONAL
- Description
This message occurs when attempts to create a file clone fail.
- Corrective Action
(None).
- Syslog Message
File clone create of clone file %s (fileid: %d) from source file %s (fileid: %d) in volume %s failed with error:%s at line %d with src_fsid %d, dst_fsid %d, src_snapid %d, dir_fileid %d, type %s, category %s.
- Parameters
clone_filename (STRING): Clone filename.
dst_fileid (INT): File identifier for destination file.
src_filename (STRING): Source filename.
src_fileid (INT): File identifier for source file.
volname (STRING): Volume name.
error (STRING): Error returned from the FlexClone® subsystem.
line_number (INT): Line number where the error has occurred.
src_fsid (INT): File system identifier of source volume.
dst_fsid (INT): File system identifier of destination volume.
snapid (INT): Snapshot copy identifier.
dir_fileid (INT): File identifier for the directory.
type (STRING): Type of Cloning.
category (STRING): Clone create requestor information.
wafl.sis.clone.unlock.snapshot
- Severity
NOTICE
- Description
This event is issued when the volume options are set such that the autodelete destroy policy is allowed to destroy backing snapshots for sis clones. The snapshot autodelete destroy policy is used as a last resort to recover space in a thin provisioned aggregate. The disruptive effect of destroying sis clone backing snapshots should be understood when setting this policy.
- Corrective Action
(None).
- Syslog Message
Unlocked sis clone backing snapshot in volume %s. Clone files based on snapshot (%d, %d) might become inconsistent.
- Parameters
name (STRING): The volume name
snapid (INT): Snapshot(tm) copy identifier.
cp_cnt (INT): The CP(Consistency Point) count. The (snapid, cp_count) pair uniquely identifies a Snapshot copy.
