      sectrace.warning events
sectrace.warning.aboutperf
- Severity
ALERT
 - Description
This message occurs when a security tracing filter is enabled. It can cause a significant performance degradation and should be disabled as soon as it is no longer needed.
 - Corrective Action
Consider disabling the Security tracing filters as soon as it is no longer needed. 'sectrace filter modify -vserver [id] -index [index] -enabled disabled'
 - Syslog Message
Security tracing is enabled on Vserver %s for the next %d minutes.
 - Parameters
vservername (STRING): Name of the vserver on which file/directory tracing is enabled.
duration (INT): Duration of the sectrace filter that is enabled.
