sectrace.warning events
sectrace.warning.aboutperf
Severity
ALERT
This message occurs when a security tracing filter is enabled. It can cause a significant performance degradation and should be disabled as soon as it is no longer needed.
Corrective Action
Consider disabling the Security tracing filters as soon as it is no longer needed. 'sectrace filter modify -vserver [id] -index [index] -enabled disabled'
Syslog Message
Security tracing is enabled on Vserver %s for the next %d minutes.
vservername (STRING): Name of the vserver on which file/directory tracing is enabled.
duration (INT): Duration of the sectrace filter that is enabled.
