mcc.network events
Creating your file...
Your file is ready
mcc.network.congestion
- Severity
NOTICE
- Description
This message occurs when a MetroCluster over IP configuration detects network congestion over the inter-cluster links (ISL) that connect sites and an action is taken to reduce further network congestion.
- Corrective Action
Verify that network between MetroCluster sites is following minimum SLA requirements and fix any such violations if needed. If the issue persists, contact NetApp technical support.
- Syslog Message
Network congestion detected. Action taken: %s.
- Parameters
action_taken (STRING): Action taken to reduce network congestion.
