ONTAP EMS reference
mcc.network events
mcc.network.congestion
Severity
NOTICE
This message occurs when a MetroCluster over IP configuration detects network congestion over the inter-cluster links (ISL) that connect sites and an action is taken to reduce further network congestion.
Corrective Action
Verify that network between MetroCluster sites is following minimum SLA requirements and fix any such violations if needed. If the issue persists, contact NetApp technical support.
Syslog Message
Network congestion detected. Action taken: %s.
action_taken (STRING): Action taken to reduce network congestion.
