savecore.nospace events
savecore.nospace EMS events occur when savecore has determined that the space available for storing the unsaved core is not sufficient.
savecore.nospace
- Severity
ERROR
- Description
Savecore has determined that the space available for storing the unsaved core is not sufficient.
- Corrective Action
Delete old or unneeded files in the root filesystem. Check in "/etc/crash" ("/crash" on Netcaches) for unneeded cores. Make sure to delete any snapshots that include the deleted files.
- Syslog Message
The available disk space (%u blocks) is not sufficient to save the core, which may need up to %d blocks.
- Parameters
avail (INT): Number of blocks available for saving the core
needed (INT): Number of blocks needed for saving the core
