nblade.flexgroupstatefulprotocolaccess events
Creating your file...
Your file is ready
Nblade.flexgroupStatefulProtocolAccess
- Severity
ERROR
- Description
This message occurs when the system detects an attempt to use Network Lock Manager (NLM) shared locks on a FlexGroup volume. FlexGroup volumes do not support NLM shared locks.
- Corrective Action
FlexGroup volumes do not support shared locks. Consider using FlexGroup volumes that support stateful protocols such as NFSv4.0,NFSv4.1,SMB1 or SMB2 in order to use shared locks.
- Syslog Message
Attempt to access FlexGroup volumes with Master Data Set ID "%u" with "%s" is denied.
- Parameters
msid (INT): Master Data Set ID of the FlexGroup volume being accessed.
protocol (STRING): Client protocol being used.
