ONTAP EMS reference
nblade.flexgroupstatefulprotocolaccess events
nblade.flexgroupstatefulprotocolaccess EMS events occur when the system detects an attempt to use Network Lock Manager (NLM) shared locks on a FlexGroup volume.
Nblade.flexgroupStatefulProtocolAccess
Severity
ERROR
This message occurs when the system detects an attempt to use Network Lock Manager (NLM) shared locks on a FlexGroup volume. FlexGroup volumes do not support NLM shared locks.
Corrective Action
FlexGroup volumes do not support shared locks. Consider using FlexGroup volumes that support stateful protocols such as NFSv4.0,NFSv4.1,SMB1 or SMB2 in order to use shared locks.
Syslog Message
Attempt to access FlexGroup volumes with Master Data Set ID "%u" with "%s" is denied.
msid (INT): Master Data Set ID of the FlexGroup volume being accessed.
protocol (STRING): Client protocol being used.
