netif.linkdown events
Creating your file...
Your file is ready
netif.linkDown
- Severity
INFORMATIONAL
- Description
This message occurs when a network link goes down or the interface is not operational when first configured up.
- Corrective Action
If the message describes the link as "down," check the cabling and switch port configuration. If the message states "controller initialization failure", report this to NetApp technical support.
- Syslog Message
%s %s: Link %s.
- Parameters
lanType (STRING): Local area network (LAN) type.
ifName (STRING): Name of the network interface.
status (STRING): Brief information about the problem.
