osc.signaturemismatch events
Creating your file...
Your file is ready
osc.signatureMismatch
- Severity
ERROR
- Description
This message occurs when the request signature sent to the object-store server does not match the signature calculated.
- Corrective Action
Verify that the secret access key is configured correctly. If it is correct, contact NetApp technical support for assistance.
- Syslog Message
Object-store %s operation server-calculated request signature does not match the signature sent to object-store server %s for bucket or container "%s" on node %s. Check the keys and signing method.
- Parameters
operation (STRING): Request name.
serverHostname (STRING): Hostname of the object-store server.
bucket (STRING): Name of the object-store bucket.
nodeUuid (STRING): UUID of the node.
