mpt.action events
mpt.action.reset.bus
Severity
NOTICE
This message occurs when the system bus is reset in the message processing technology (MPT) adapter driver.
Corrective Action
(None).
Syslog Message
Bus reset on path %s for device status %s.
path (STRING): Device path.
msg (STRING): Detail about device status.
mpt.action.reset.dev
Severity
NOTICE
This message occurs when the system device is reset in the message processing technology (MPT) adapter driver.
Corrective Action
(None).
Syslog Message
Device reset on path %s for device status %s.
