mpt.action events
mpt.action.reset.bus
- Severity
NOTICE
- Description
This message occurs when the system bus is reset in the message processing technology (MPT) adapter driver.
- Corrective Action
(None).
- Syslog Message
Bus reset on path %s for device status %s.
- Parameters
path (STRING): Device path.
msg (STRING): Detail about device status.
mpt.action.reset.dev
- Severity
NOTICE
- Description
This message occurs when the system device is reset in the message processing technology (MPT) adapter driver.
- Corrective Action
(None).
- Syslog Message
Device reset on path %s for device status %s.
- Parameters
