scsiblade.prop events
scsiblade.prop.done.error
- Severity
EMERGENCY
- Description
This message occurs when a CTRAN "proposal done" message is not received. The SAN management plane is inoperative for the Vserver until the corrective action is taken.
- Corrective Action
For further information about correcting the problem, search the knowledgebase of the NetApp technical support support web site for the "scsiblade.prop.done.error" keyword.
- Syslog Message
An internal error occurred in a %s group (MSID: %llu). The Vserver %s will not be able to process any management commands.
- Parameters
groupType (STRING): CTRAN group type.
volumeMSID (LONGINT): MSID of the volume in case the CTRAN group type is "volume"; otherwise, 0.
vserver (STRING): Name or UUID of the Vserver.
