fmmb.oldformatcleared events
Creating your file...
Your file is ready
fmmb.oldFormatCleared
- Severity
INFORMATIONAL
- Description
This event is issued when the older format HA mailboxes (special area of disk used for bookkeeping) are cleared on an upgrade from a pre 7.0 version of Data ONTAP to a 7.0 or later version.
- Corrective Action
(None).
- Syslog Message
Clearing content of %s old format HA mailboxes (special area of disk used for bookkeeping).
- Parameters
whichone (STRING): Either local or partner to indicate which set of HA mailboxes are being cleared.
