ccma.disabled events
Creating your file...
Your file is ready
ccma.disabled
- Severity
ERROR
- Description
This message occurs when the Performance Archive has been disabled for more than an hour. This is caused by setting the -is-enabled flag to false. This message will be repeated every hour that the archiver is turned off. The messages will only displayed once a day.
- Corrective Action
Run the 'statistics archive config modify -is-enable true' command. This will enable the Performance Archive.
- Syslog Message
The Performance Archive has been disabled for more than an hour. It is Important for the analysis and diagnoses of performance related issues. Consider enabling it.
- Parameters
(None).
