ONTAP EMS reference
esh.unexpected events
esh.unexpected EMS events occur when a disk shelf reports an unknown status.
esh.unexpected.status
Severity
ALERT
This message occurs when a disk shelf reports an unknown status.
Corrective Action
Ensure that the shelf module firmware and ONTAP® software are compatible versions. Find firmware versions at the NetApp technical support web site.
Syslog Message
Unexpected ESH status of: %d.
status (INT): Unexpected/unknown status code that was received.
