ONTAP EMS reference
cmpr.algo events
cmpr.algo.not.enabled
Severity
ALERT
This message occurs when compression algorithm specified has not been enabled on the node.
Corrective Action
Contact technical support.
Syslog Message
Volume '%s' has '%s' compression enabled but the necessary bootarg(s) have not been set on the node.
vol (STRING): Volume name.
comp_algo (STRING): Compression Algorithm.
