ONTAP EMS reference
wafl.gd events
wafl.gd EMS events occur when ONTAP encounters issues associated with granular data allocation and conversion operations.
wafl.gd.alloc.size.rsrv.fail
Severity
ERROR
This message occurs when reserving allocation size fails for a file using granular data because there is no space available in the volume.
Corrective Action
Create space by increasing the volume or aggregate sizes, or by deleting data or deleting Snapshot copies. To increase a volume's size, use the "volume size" command. To delete a volume's Snapshot copies, use the "volume snapshot delete" command. To increase an aggregate's size, add disks by using the "storage aggregate add-disks" command. Aggregate Snapshot copies are deleted automatically when the aggregate is full.
Syslog Message
Reserving allocation size for fileid "%d" on volume "%s%s%s%s" fails because there is no space available in the volume.
fileid (INT): File identifier.
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application universal unique identifier (UUID).
volident (STRING): Volume identifier that uniquely identifies the volume in cases where the volume name itself is insufficient.
wafl.gd.convert.scan.running
Severity
NOTICE
This message occurs when converting a file to use granular data fails because a scanner is currently running on the volume. The conversion cannot be completed until the scan is complete or filesystem inconsistencies can occur. Granular data conversion is required for non-disruptive file moves that occur as part of volume rebalancing.
Corrective Action
Retry the operation after some time to allow the scan to complete. If the problem persists, contact NetApp technical support for assistance.
Syslog Message
Granular data conversion failed for fileid "%d" on volume "%s%s%s%s" because scan "%s" is currently running on the volume.
app (STRING): Application UUID.
scantype (STRING): Type of scan.
wafl.gd.convert.unknown.pvbn
Severity
NOTICE
This message occurs when converting a file to use granular data fails because the file contains unresolved physical block numbers (PVBNs). Unresolved PVBNs occur when you move a volume to a different aggregate. PVBNs are resolved by a background process following the volume move.
Corrective Action
Retry the operation after some time to allow the background process to complete.
Syslog Message
Granular data conversion failed for fileid "%d" on volume "%s%s%s%s" because the inode contains unresolved PVBNs.
