ONTAP EMS reference
wafl.gd events
wafl.gd.convert.scan.running
Severity
NOTICE
This message occurs when converting a file to use granular data fails because a scanner is currently running on the volume. The conversion cannot be completed until the scan is complete or filesystem inconsistencies can occur. Granular data conversion is required for non-disruptive file moves that occur as part of volume rebalancing.
Corrective Action
Retry the operation after some time to allow the scan to complete. If the problem persists, contact NetApp technical support for assistance.
Syslog Message
Granular data conversion failed for fileid "%d" on volume "%s%s%s%s" because scan "%s" is currently running on the volume.
fileid (INT): File identifier.
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Volume identifier that uniquely identifies the volume in cases where the volume name itself is insufficient.
scantype (STRING): Type of scan.
wafl.gd.convert.unknown.pvbn
Severity
NOTICE
This message occurs when converting a file to use granular data fails because the file contains unresolved physical block numbers (PVBNs). Unresolved PVBNs occur when you move a volume to a different aggregate. PVBNs are resolved by a background process following the volume move.
Corrective Action
Retry the operation after some time to allow the background process to complete.
Syslog Message
Granular data conversion failed for fileid "%d" on volume "%s%s%s%s" because the inode contains unresolved PVBNs.
