config.nocheck events
Creating your file...
Your file is ready
config.NoCheck
- Severity
NOTICE
- Description
This message occurs when the system should be halting, but it cannot because the "no-config-check? " environment variable is set to true.
- Corrective Action
(None).
- Syslog Message
This is an illegal configuration. However the Filer is not halting due to no-config-check? being set to true.
- Parameters
(None).
