ONTAP EMS reference
config.nocheck events
config.nocheck EMS events occur when the system should be halting but cannot because the "no-config-check?" environment variable is set to true.
config.NoCheck
Severity
NOTICE
This message occurs when the system should be halting, but it cannot because the "no-config-check? " environment variable is set to true.
Corrective Action
(None).
Syslog Message
This is an illegal configuration. However the Filer is not halting due to no-config-check? being set to true.
(None).
