raid.unsupported events
Creating your file...
raid.unsupported.bitformat
- Severity
ERROR
- Description
This message occurs when configuration management detects that the disk belongs to a 32-bit aggregate, the use of which has been deprecated. The disk is removed from service.
- Corrective Action
Install a version of Data ONTAP® that supports the 32-bit aggregate, or remove the 32-bit aggregate disks.
- Syslog Message
The label on %s indicates that the disk belongs to a 32-bit aggregate, the use of which has been deprecated.
- Parameters
disk_info (STRING): Information about the disk object, including disk name, path, shelf, bay, serial number, vendor, model, RPM, and carrier serial number.
shelf (STRING): Identifier of the shelf where the disk is located.
bay (STRING): Disk bay within the shelf where the disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model string of the disk.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk.
disk_rpm (STRING): Rotational speed of the disk, in RPM.
failure_reason (STRING): Text description of the storage error leading to disk failure.
carrier (STRING): Unique ID of the carrier in which the disk is installed.
site (STRING): For a MetroCluster(tm) configuration, indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is Local.
raid.unsupported.cksumtype
- Severity
ERROR
- Description
This message occurs when configuration management detects that the disk belongs to a ZCS aggregate, the use of which has been deprecated. The disk is removed from service.
- Corrective Action
Install a version of Data ONTAP® that supports the ZCS aggregate, or remove the ZCS aggregate disks.
- Syslog Message
The label on %s indicates that the disk belongs to a ZCS aggregate, the use of which has been deprecated.
- Parameters
