ONTAP EMS reference
ffm.dataip events
ffm.dataip.failedToHost
Severity
NOTICE
This message occurs when a data IP address was failed to host on the node. Data access through this IP address is not available.
Corrective Action
(None).
Syslog Message
Data IP address %s was failed to host by the NFS protocol service on the node %s (ID: %u).
dataip (STRING): The IP address that was failed to host.
nodename (STRING): Name of the node on which the data IP was failed to host.
nodeid (INT): Unique identifier of the node on which the data IP was failed to host.
ffm.dataip.notUnhosted
Severity
NOTICE
This message occurs when a data IP address is not unhosted on the node.
Corrective Action
(None).
Syslog Message
The NFS protocol service could not unhost data IP address "%s" on node "%s" (ID: %u).
dataip (STRING): IP address that could not be unhosted.
nodename (STRING): Name of the node on which the data IP could not be unhosted.
nodeid (INT): Unique identifier of the node on which the data IP could not be unhosted.
ffm.dataip.successfullyHosted
Severity
NOTICE
This message occurs when a data IP address was successfully hosted on the node. Data access through this IP address is now available.
Corrective Action
(None).
Syslog Message
Data IP address %s was hosted by the NFS protocol service on the node %s (ID: %u).
dataip (STRING): The IP address that was hosted.
nodename (STRING): Name of the node on which the data IP was hosted.
nodeid (INT): Unique identifier of the node on which the data IP was hosted.
ffm.dataip.unhostSuccess
Severity
NOTICE
This message occurs when a data IP address is successfully unhosted from the node. Data access through this IP address is not available.
Corrective Action
(None).
Syslog Message
The NFS protocol service unhosted data IP address "%s" on node "%s" (ID: %u).
dataip (STRING): IP address that was unhosted.
nodename (STRING): Name of the node on which the data IP was unhosted.
nodeid (INT): Unique identifier of the node on which the data IP was unhosted.
