ffm.dataip events
ffm.dataip.failedToHost
- Severity
NOTICE
- Description
This message occurs when a data IP address was failed to host on the node. Data access through this IP address is not available.
- Corrective Action
(None).
- Syslog Message
Data IP address %s was failed to host by the NFS protocol service on the node %s (ID: %u).
- Parameters
dataip (STRING): The IP address that was failed to host.
nodename (STRING): Name of the node on which the data IP was failed to host.
nodeid (INT): Unique identifier of the node on which the data IP was failed to host.
ffm.dataip.notUnhosted
- Severity
NOTICE
- Description
This message occurs when a data IP address is not unhosted on the node.
- Corrective Action
(None).
- Syslog Message
The NFS protocol service could not unhost data IP address "%s" on node "%s" (ID: %u).
- Parameters
dataip (STRING): IP address that could not be unhosted.
nodename (STRING): Name of the node on which the data IP could not be unhosted.
nodeid (INT): Unique identifier of the node on which the data IP could not be unhosted.
ffm.dataip.successfullyHosted
- Severity
NOTICE
- Description
This message occurs when a data IP address was successfully hosted on the node. Data access through this IP address is now available.
- Corrective Action
(None).
- Syslog Message
Data IP address %s was hosted by the NFS protocol service on the node %s (ID: %u).
- Parameters
dataip (STRING): The IP address that was hosted.
nodename (STRING): Name of the node on which the data IP was hosted.
nodeid (INT): Unique identifier of the node on which the data IP was hosted.
ffm.dataip.unhostSuccess
- Severity
NOTICE
- Description
This message occurs when a data IP address is successfully unhosted from the node. Data access through this IP address is not available.
- Corrective Action
(None).
- Syslog Message
The NFS protocol service unhosted data IP address "%s" on node "%s" (ID: %u).
- Parameters
dataip (STRING): IP address that was unhosted.
nodename (STRING): Name of the node on which the data IP was unhosted.
nodeid (INT): Unique identifier of the node on which the data IP was unhosted.
