air.enabled events
Creating your file...
Your file is ready
air.enabled.fg.qtree
- Severity
NOTICE
- Description
This message occurs in a FlexGroup, when the qtree support is enabled on the volume, but disabled on one or more constituent volumes. ONTAP® software automatically enabled the qtree support on the relevant constituent volumes.
- Corrective Action
This message indicates that the qtree support is enabled on the volume, but disabled in one or more constituents within the FlexGroup. ONTAP® software automatically enabled the qtree support in the relevant constituent FlexGroup volumes.
- Syslog Message
Enabled qtree support in FlexGroup constituent volume %s after detecting inconsistency in %s.
- Parameters
volume (STRING): Name of the volume.
source (STRING): Location of the failing metadata validation.
