ONTAP EMS reference
air.enabled events
air.enabled.fg.qtree
Severity
NOTICE
This message occurs in a FlexGroup, when the qtree support is enabled on the volume, but disabled on one or more constituent volumes. ONTAP® software automatically enabled the qtree support on the relevant constituent volumes.
Corrective Action
This message indicates that the qtree support is enabled on the volume, but disabled in one or more constituents within the FlexGroup. ONTAP® software automatically enabled the qtree support in the relevant constituent FlexGroup volumes.
Syslog Message
Enabled qtree support in FlexGroup constituent volume %s after detecting inconsistency in %s.
volume (STRING): Name of the volume.
source (STRING): Location of the failing metadata validation.
