ata.excessive events
Creating your file...
Your file is ready
ata.excessive.latency
- Severity
NOTICE
- Description
This message occurs when an I/O request to the ATA driver in ONTAP® Select takes longer than five seconds. This might be an indication of an overloaded or misconfigured back-end storage subsystem.
- Corrective Action
If possible, reduce the I/O load on the system. Verify that the device is configured correctly and is functioning correctly.
- Syslog Message
Excessive latency on ATA device %s
- Parameters
ata_latency_message (STRING): ATA high latency message
