auto.update events
Creating your file...
auto.update.action
- Severity
NOTICE
- Description
This message occurs when an action is applied to an automatic update request. This step requires input from the customer or a pre-configured default setting.
- Corrective Action
(None).
- Syslog Message
Automatic update: Applied the action "%s" to package: %s.
- Parameters
action (STRING): Action selected for the automatic update request. Possible actions are "install", "schedule", or "dismiss".
package_description (STRING): Information about the package.
package_id (STRING): Unique identifier for the package.
auto.update.eula.accepted
- Severity
NOTICE
- Description
This message occurs when the customer has accepted the End User License Agreement (EULA). This is required before the Automatic update feature is enabled.
- Corrective Action
(None).
- Syslog Message
Automatic update: End User License Agreement accepted by "%s".
- Parameters
user (STRING): Name of the user account that accepted the EULA.
auto.update.eula.reset
- Severity
NOTICE
- Description
This message occurs when the Automatic update feature is disabled and the End User License Agreement (EULA) is no longer considered accepted.
- Corrective Action
(None).
- Syslog Message
Automatic update: Feature has been disabled by "%s".
- Parameters
user (STRING): Name of the user account that disabled the EULA.
auto.update.expired
- Severity
NOTICE
- Description
This message occurs when an automatic update request has not been acted upon before the request expiration date.
- Corrective Action
(None).
- Syslog Message
Automatic update: Request expired on %s for package: %s.
- Parameters
expired_date_time (STRING): Date and time when the request expired.
auto.update.failure
- Severity
ERROR
- Description
This message occurs when an automatic update has failed to complete.
- Corrective Action
Fix the issues causing the failure and retry the automatic update. If the issue persists, contact NetApp technical support.
- Syslog Message
Automatic update: Failed update for package: %s. Error: %s.
- Parameters
error_msg (STRING): String containing details regarding the cause of the failure.
stage (STRING): Stage at which the update failed.
auto.update.received
- Severity
NOTICE
- Description
This message occurs when the automatic update information is received from the AutoSupport OnDemand server.
- Corrective Action
(None).
- Syslog Message
Automatic update: Received update for package: %s.
- Parameters
auto.update.retracted
- Severity
NOTICE
- Description
This message occurs when an automatic update request has been superseded, retracted or otherwise considered unnecessary.
- Corrective Action
(None).
- Syslog Message
Automatic update: Request retracted for package: %s.
- Parameters
auto.update.success
- Severity
NOTICE
- Description
This message occurs when an automatic update has completed successfully.
- Corrective Action
(None).
- Syslog Message
Automatic update: Successfully updated package: %s.
- Parameters
