ONTAP EMS reference
auto.update events
auto.update.action
Severity
NOTICE
This message occurs when an action is applied to an automatic update request. This step requires input from the customer or a pre-configured default setting.
Corrective Action
(None).
Syslog Message
Automatic update: Applied the action "%s" to package: %s.
action (STRING): Action selected for the automatic update request. Possible actions are "install", "schedule", or "dismiss".
package_description (STRING): Information about the package.
package_id (STRING): Unique identifier for the package.
auto.update.eula.accepted
Severity
NOTICE
This message occurs when the customer has accepted the End User License Agreement (EULA). This is required before the Automatic update feature is enabled.
Corrective Action
(None).
Syslog Message
Automatic update: End User License Agreement accepted by "%s".
user (STRING): Name of the user account that accepted the EULA.
auto.update.eula.reset
Severity
NOTICE
This message occurs when the Automatic update feature is disabled and the End User License Agreement (EULA) is no longer considered accepted.
Corrective Action
(None).
Syslog Message
Automatic update: Feature has been disabled by "%s".
user (STRING): Name of the user account that disabled the EULA.
auto.update.expired
Severity
NOTICE
This message occurs when an automatic update request has not been acted upon before the request expiration date.
Corrective Action
(None).
Syslog Message
Automatic update: Request expired on %s for package: %s.
expired_date_time (STRING): Date and time when the request expired.
auto.update.failure
Severity
ERROR
This message occurs when an automatic update has failed to complete.
Corrective Action
Fix the issues causing the failure and retry the automatic update. If the issue persists, contact NetApp technical support.
Syslog Message
Automatic update: Failed update for package: %s. Error: %s.
error_msg (STRING): String containing details regarding the cause of the failure.
stage (STRING): Stage at which the update failed.
auto.update.received
Severity
NOTICE
This message occurs when the automatic update information is received from the AutoSupport OnDemand server.
Corrective Action
(None).
Syslog Message
Automatic update: Received update for package: %s.
auto.update.retracted
Severity
NOTICE
This message occurs when an automatic update request has been superseded, retracted or otherwise considered unnecessary.
Corrective Action
(None).
Syslog Message
Automatic update: Request retracted for package: %s.
auto.update.success
Severity
NOTICE
This message occurs when an automatic update has completed successfully.
Corrective Action
(None).
Syslog Message
Automatic update: Successfully updated package: %s.
