certificate.invalid events
certificate.invalid.chain
- Severity
ERROR
- Description
This message occurs when an installed certificate record contains multiple X.509 certificates. Such records are not treated consistently by the system, but were unintentionally permitted in prior releases.
- Corrective Action
Delete the problematic record by using the "security certificate delete" command. Install the constituent certificates separately by using the "security certificate install" command once for each certificate.
- Syslog Message
The certificate record with UUID %s, named "%s" in Vserver "%s", contains multiple certificates.
- Parameters
uuid (STRING): UUID of the offending record.
cert_name (STRING): Name (unique within a Vserver) of the offending record.
vserver (STRING): Name of the Vserver in which the offending record is installed.
