ONTAP EMS reference
certificate.invalid events
certificate.invalid EMS events occur when an installed certificate record contains multiple X.509 certificates.
certificate.invalid.chain
Severity
ERROR
This message occurs when an installed certificate record contains multiple X.509 certificates. Such records are not treated consistently by the system, but were unintentionally permitted in prior releases.
Corrective Action
Delete the problematic record by using the "security certificate delete" command. Install the constituent certificates separately by using the "security certificate install" command once for each certificate.
Syslog Message
The certificate record with UUID %s, named "%s" in Vserver "%s", contains multiple certificates.
uuid (STRING): UUID of the offending record.
cert_name (STRING): Name (unique within a Vserver) of the offending record.
vserver (STRING): Name of the Vserver in which the offending record is installed.
