cf.headswap events
Creating your file...
cf.headswap.abort
- Severity
INFORMATIONAL
- Description
This message occurs when the headswap on the partner node is aborted.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
partner_sysid (LONGINT): Value of the partner system ID after aborting the headswap.
cf.headswap.clear.partner
- Severity
INFORMATIONAL
- Description
This message occurs when the disks are manually reassigned to a new partner. The head swap information has been cleared.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
(None).
cf.headswap.complete
- Severity
INFORMATIONAL
- Description
This message occurs when the headswap of a node is completed.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
old_sysid (LONGINT): Value of the partner system ID before completion of the headswap.
new_sysid (LONGINT): Value of the partner system ID after completion of the headswap.
cf.headswap.detected.local
- Severity
INFORMATIONAL
- Description
This message occurs when a headswap on the local node is detected.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
old_local_sysid (LONGINT): System ID of the node that is being replaced.
new_local_sysid (LONGINT): System ID of the new node that is replacing the old node.
cf.headswap.detected.partner
- Severity
INFORMATIONAL
- Description
This message occurs when a headswap on the partner node is detected.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
old_partner_sysid (LONGINT): System ID of the partner that is being replaced.
new_partner_sysid (LONGINT): System ID of the new partner that is replacing the old partner.
cf.headswap.state.change
- Severity
INFORMATIONAL
- Description
This message occurs when the headswap state changes. The headswap state is written to the primary mailbox. The possible values are HEADSWAP_NONE, HEADSWAP_START, HEADSWAP_CFO_START, HEADSWAP_CFO_END, and HEADSWAP_SFO_START.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
old_state_string (STRING): Old value of the headswap state.
new_state_string (STRING): New value of the headswap state.
