ONTAP EMS reference
cf.headswap events
cf.headswap.abort
Severity
INFORMATIONAL
This message occurs when the headswap on the partner node is aborted.
Corrective Action
(None).
Syslog Message
(None).
partner_sysid (LONGINT): Value of the partner system ID after aborting the headswap.
cf.headswap.clear.partner
Severity
INFORMATIONAL
This message occurs when the disks are manually reassigned to a new partner. The head swap information has been cleared.
Corrective Action
(None).
Syslog Message
(None).
(None).
cf.headswap.complete
Severity
INFORMATIONAL
This message occurs when the headswap of a node is completed.
Corrective Action
(None).
Syslog Message
(None).
old_sysid (LONGINT): Value of the partner system ID before completion of the headswap.
new_sysid (LONGINT): Value of the partner system ID after completion of the headswap.
cf.headswap.detected.local
Severity
INFORMATIONAL
This message occurs when a headswap on the local node is detected.
Corrective Action
(None).
Syslog Message
(None).
old_local_sysid (LONGINT): System ID of the node that is being replaced.
new_local_sysid (LONGINT): System ID of the new node that is replacing the old node.
cf.headswap.detected.partner
Severity
INFORMATIONAL
This message occurs when a headswap on the partner node is detected.
Corrective Action
(None).
Syslog Message
(None).
old_partner_sysid (LONGINT): System ID of the partner that is being replaced.
new_partner_sysid (LONGINT): System ID of the new partner that is replacing the old partner.
cf.headswap.state.change
Severity
INFORMATIONAL
This message occurs when the headswap state changes. The headswap state is written to the primary mailbox. The possible values are HEADSWAP_NONE, HEADSWAP_START, HEADSWAP_CFO_START, HEADSWAP_CFO_END, and HEADSWAP_SFO_START.
Corrective Action
(None).
Syslog Message
(None).
old_state_string (STRING): Old value of the headswap state.
new_state_string (STRING): New value of the headswap state.
