clus.reboot events
Creating your file...
clus.reboot.internalError
- Severity
ALERT
- Description
This message occurs when the cluster reboot detection feature detects an internal software error due to insufficient system resources.
- Corrective Action
Reboot the node by using the "system node reboot -node <nodename>" command. Contact NetApp technical support if further assistance is needed.
- Syslog Message
Cluster reboot detection feature detected an internal software error. Error: '%s'.
- Parameters
error (STRING): Internal software error.
clus.reboot.noBootSequence
- Severity
ERROR
- Description
This message occurs when the cluster reboot detection feature fails to obtain the node boot sequence from the /var/BOOT_SEQ file.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Cluster reboot detection feature failed to obtain the node boot sequence from /var/BOOT_SEQ file.
- Parameters
(None).
clus.reboot.persistencyError
- Severity
ERROR
- Description
This message occurs when the cluster reboot detection feature fails to save the node reboot information persistently.
- Corrective Action
Reboot the node by using the "system node reboot -node nodename" command. Contact NetApp technical support if further assistance is needed.
- Syslog Message
Cluster reboot detection feature failed to save the node reboot information persistently. Error: '%s'.
- Parameters
error (STRING): Error returned by the save operation.
clus.reboot.rebootDetected
- Severity
NOTICE
- Description
This message occurs when a cluster reboot is detected.
- Corrective Action
(None).
- Syslog Message
Cluster reboot was detected at %s. Sequence number for the cluster reboot was %d. Estimated beginning time of the cluster reboot was %s.
- Parameters
endtime (STRING): End time of the cluster reboot.
sequence (LONGINT): Sequence number of the detected cluster reboot.
begintime (STRING): Estimated beginning time of the cluster reboot based on the last known time the cluster was operational.
