ONTAP EMS reference
clus.reboot events
clus.reboot.internalError
Severity
ALERT
This message occurs when the cluster reboot detection feature detects an internal software error due to insufficient system resources.
Corrective Action
Reboot the node by using the "system node reboot -node <nodename>" command. Contact NetApp technical support if further assistance is needed.
Syslog Message
Cluster reboot detection feature detected an internal software error. Error: '%s'.
error (STRING): Internal software error.
clus.reboot.noBootSequence
Severity
ERROR
This message occurs when the cluster reboot detection feature fails to obtain the node boot sequence from the /var/BOOT_SEQ file.
Corrective Action
Contact NetApp technical support.
Syslog Message
Cluster reboot detection feature failed to obtain the node boot sequence from /var/BOOT_SEQ file.
(None).
clus.reboot.persistencyError
Severity
ERROR
This message occurs when the cluster reboot detection feature fails to save the node reboot information persistently.
Corrective Action
Reboot the node by using the "system node reboot -node nodename" command. Contact NetApp technical support if further assistance is needed.
Syslog Message
Cluster reboot detection feature failed to save the node reboot information persistently. Error: '%s'.
error (STRING): Error returned by the save operation.
clus.reboot.rebootDetected
Severity
NOTICE
This message occurs when a cluster reboot is detected.
Corrective Action
(None).
Syslog Message
Cluster reboot was detected at %s. Sequence number for the cluster reboot was %d. Estimated beginning time of the cluster reboot was %s.
endtime (STRING): End time of the cluster reboot.
sequence (LONGINT): Sequence number of the detected cluster reboot.
begintime (STRING): Estimated beginning time of the cluster reboot based on the last known time the cluster was operational.
