config.localswitch events
Creating your file...
Your file is ready
config.localswitch
- Severity
EMERGENCY
- Description
This message occurs when a disk is found attached via both local connection and a switch. This is permitted in debug. The system will be halted in non-debug.
- Corrective Action
(None).
- Syslog Message
Disk %s is attached via a local connection and a switch. This is an illegal configuration.
- Parameters
disk (STRING): Name of the disk.
