ONTAP EMS reference
config.localswitch events
config.localswitch EMS events occur when a disk is found attached via both local connection and a switch.
config.localswitch
Severity
EMERGENCY
This message occurs when a disk is found attached via both local connection and a switch. This is permitted in debug. The system will be halted in non-debug.
Corrective Action
(None).
Syslog Message
Disk %s is attached via a local connection and a switch. This is an illegal configuration.
disk (STRING): Name of the disk.
