ha.takeoverimpdegraded events
ha.takeoverImpDegraded
Severity
ALERT
This message occurs when the partner node is down and it is currently impossible to perform a takeover because the partner mailbox disks are not available.
Corrective Action
Check connectivity to the partner disks. Identify the mailbox disks on the partner node by using the "storage failover show -instance" command. Verify that this node has connectivity to the partner mailbox disks by using the "storage disk show -instance" command. Resolve any connectivity issues by fixing cabling or shelf issues.
Syslog Message
Takeover of the partner node is impossible due to lack of connectivity to the partner mailbox disks.
(None).
