km.okmdb events
Creating your file...
km.okmdb.read.failed
- Severity
ALERT
- Description
This message occurs when a read of the Onboard Key Manager's database file fails. This may occur when the Onboard Key Manager has been configured to use a USB based mount-point and the USB device has not been mounted on the node.
- Corrective Action
Check that the USB device is attached to the node.
- Syslog Message
The system is not able to read from the Onboard Key Manager's database file.
- Parameters
(None).
km.okmdb.write.failed
- Severity
ALERT
- Description
This message occurs when a write to the Onboard Key Manager's database file fails. This may occur when the Onboard Key Manager has been configured to use a USB based mount-point and the USB device has either not been mounted on the node or the USB device is write-protected.
- Corrective Action
Check that the USB device is attached to the node and that it is not write-protected.
- Syslog Message
The system is not able to write to the Onboard Key Manager's database file.
- Parameters
(None).
