ONTAP EMS reference
km.okmdb events
km.okmdb.read.failed
Severity
ALERT
This message occurs when a read of the Onboard Key Manager's database file fails. This may occur when the Onboard Key Manager has been configured to use a USB based mount-point and the USB device has not been mounted on the node.
Corrective Action
Check that the USB device is attached to the node.
Syslog Message
The system is not able to read from the Onboard Key Manager's database file.
(None).
km.okmdb.write.failed
Severity
ALERT
This message occurs when a write to the Onboard Key Manager's database file fails. This may occur when the Onboard Key Manager has been configured to use a USB based mount-point and the USB device has either not been mounted on the node or the USB device is write-protected.
Corrective Action
Check that the USB device is attached to the node and that it is not write-protected.
Syslog Message
The system is not able to write to the Onboard Key Manager's database file.
(None).
