lifp.net events
Creating your file...
lifp.net.bdmismatch
- Severity
ERROR
- Description
This message occurs while assigning network ports to broadcast domains, when LIF Placement subnet discovery finds a port that is assigned to a broadcast domain that is different from the broadcast domain to which other ports in the same physical broadcast domain are assigned.
- Corrective Action
Ports assigned to broadcast-domains need to be corrected by the admin. The ports in one physical broadcast domain must be assigned to a single broadcast-domain.
- Syslog Message
In IPspace %s, other ports in the same physical broadcast domain are assigned to broadcast-domain %s but %s is assigned to broadcast-domain %s.
- Parameters
ipspacename (STRING): IPspace name.
broadcastdomainOnOtherPorts (STRING): Broadcast-domain name.
port (STRING): Port name.
broadcastdomainOnCurrentPort (STRING): Broadcast-domain name.
